TwinTurbo.NET: Nissan 300ZX forum - return line test results>>
Subject return line test results>>
Posted by komplexZTT on May 30, 2024 at 9:24 AM
  This message has been viewed 380 times.
In Reply To thanks for the input! posted by komplexZTT on May 23, 2024 at 08:41 AM
Message Idle, No Vac to FPR 44psi, 12psi return
Idle, Vac to FPR 35psi, 13psi return
Short drive
Idle, No Vac to FPR 38psi, 8psi return
Idle, Vac to FPR 28psi, 9psi return
Sooo, doesn't seem like return is restricted, FPR or pump?...
I would think the FPR should hold absolute pressure, no matter pump is 50-100psi, regulator should be to set value(43.5)? Isn't that the point of a regulator ...so FPR bad? I can adjust it and get pressure back up..so not that the pressure isn't available from pump.
Thoughts
2+2=4; 2+0=2; 4>2 : 2+2 > 2+0.
