TwinTurbo.NET: Nissan 300ZX forum - I always got noise without OEM shims on OEM calipers
Subject I always got noise without OEM shims on OEM calipers
Posted by Polishzx on May 28, 2024 at 7:25 PM
  This message has been viewed 359 times.
In Reply To are the shims that come with aftermarket pads enough? posted by Chemist on May 28, 2024 at 05:25 PM
Message This was always with Semi-Metallic pads though, which came with their own shims that you installed. Going back to OEM shims was the answer, perfectly quiet afterwards. Recently upgraded to Brembos up front, I had to use the shims that came with the pads which were the exact model of the pads I was using with the z32 calipers. I got no noise whatsoever with the aftermarket shims on the new calipers which is interesting. Still using OEM shims on rears.
