TwinTurbo.NET: Nissan 300ZX forum - Probably failed due to using PS fluid instead of
Zxpress
on April 27, 2024 at 10:35 AM
Correct power steering fluid?
posted by ZXPilot58
on April 26, 2024 at 09:13 PM
transmission fluid. My brother's old toyota specifically says damage to the pump will occur if you don't use transmission fluid.
ZXPilot58
21:13:54 04/26/24
Re: Correct power steering fluid?
ZXPilot58
21:19:10 04/26/24
Dexron 3 ATF. If your pump failed, you should
itsa300zx
23:56:13 04/26/24
^^ 2nd ATF or go home (n/m)
FrozTTy
08:34:05 04/27/24
Probably failed due to using PS fluid instead of -
Zxpress
10:35:10 04/27/24
What Express said. (n/m)
Z Force1
11:20:33 04/27/24
