TwinTurbo.NET: Nissan 300ZX forum - thanx, from what i can tell......
Subject thanx, from what i can tell......
Posted by desertheat on April 10, 2024 at 11:26 AM
  This message has been viewed 356 times.
In Reply To Unfortunately, there's no easy way ! posted by zx299 on April 10, 2024 at 12:37 AM
Message you don't really need to replace the whole assembly. the roller and stem can be unscrewed. however like you said you have little room to work, and if you try to grab the stem with a pliers and twist likely the whole assembly will spin. i'll probably give it a shot. if it doesn't work i'll guess i'll be removing all the door trim and window. yes, there are pros and cons to owning a classic car. get used to it.
