TwinTurbo.NET: Nissan 300ZX forum - IIRC, the pass side coolant heater core tube is the feed
Subject IIRC, the pass side coolant heater core tube is the feed
Posted by itsa300zx on February 16, 2024 at 11:24 AM
  This message has been viewed 352 times.
In Reply To So I looked at the FSM and saw there are two hoses per turbo posted by LA z on February 14, 2024 at 05:12 PM
Message into the turbo.
If you have the TB coolant bypass done, this is the coolant flow path:
Water pump>block/heads>pass side heater core tube> branches to both turbos and dash>returns to driver side heater core tube>Radiator.
Green arrows show the coolant to the turbos path.
IMG-8268-rear-turbo-coolant-feed
