TwinTurbo.NET: Nissan 300ZX forum - Speed control device on tranny >>>>>>>>>>>>
Subject Speed control device on tranny >>>>>>>>>>>>
Posted by ZUL8TR on December 12, 2023 at 5:39 AM
  This message has been viewed 392 times.
Message The 1992 300zx NA manual 2+0 uses a OEM 25911-30P10 speed control and the TT uses a 25911-40P10.
Except for the different plastic gear on the shafts will the TT speed control work on my NA with the correct gear on my NA assuming that the NA gear will fit on the TT shaft?
Do the NA and TT speed control have same calibration for their AC voltage output vs their rpm?
Is the 1992 NA the same dimension as the 1992 TT speed control?
Reason I ask the OEM TT 25911-40P10 units are readily available and the OEM NA 25911-30P10 units are not.
Thank you for the help.
ZUL8TR
