TwinTurbo.NET: Nissan 300ZX forum - Lets get some details...
Subject Lets get some details...
Posted by Agent X on December 11, 2023 at 12:28 PM
  This message has been viewed 302 times.
In Reply To No heat from vents posted by Hiruzaiz32 on December 11, 2023 at 11:53 AM
Message You say you fixed the AC, but what did you fix/do? (for example: if you took things apart to fix the AC you may have left something unplugged or disconnected, depending on what you worked on.)
Did you do anything to the coolant between when it was working fine and now?
You said: "When I first got the car, the heater worked and it was so toasty. After some time it just stopped working and I think it could be the coolant?" If you didn't do anything to the coolant then I wouldn't think that it would be the cause.
As for your temperature- that gauge isn't really accurate, but mine sits around the same spot. I have an aftermarket gauge that is much more accurate and will fluctuate quite a bit in the summer and the stock gauge doesn't move much, if any.
Conversation between my sister and my wife (shortly before we
got married):
Wife: "You know, sometimes I think he loves that Z more than he
does me."
Sister: "He probably does, and as long as you're okay with that,
everything will be fine."
