TwinTurbo.NET: Nissan 300ZX forum - How about the third link(knee) on the front suspension?
Subject How about the third link(knee) on the front suspension?
Posted by Doug71zt(CAN) on December 05, 2023 at 2:08 PM
  This message has been viewed 319 times.
In Reply To Severe Brake Shudder - Z32 Track Car posted by NormZOH on December 04, 2023 at 12:59 PM
Message Either front upper control arm bushings or the kingpin joint (bearings or a worn kingpin).
Other place to look is to make sure that your new rotors are not hanging up on the center bore of the hub instead of mating flat on the hub face surface.
Have a close look at your inner tie rod ends (and everything else) with the strut lower mount disconnected and the suspension held at ride height with the car body on jack stands and the front suspension supported by a jack or block under the lower control arm.
What suspension mods do you have on the front? What style of tension rods?
