TwinTurbo.NET: Nissan 300ZX forum - Timing belt question:
Subject Timing belt question:
Posted by ctheobal on November 12, 2023 at 12:12 PM
  This message has been viewed 298 times.
Message I can get the marks on the belt to line up with the marks on all 4 cam gears and the crank gear but only the crank gear is lined up with the mark on the oil pump. All the cam gears seem to be 1 tooth off. Is that normal? If not, any suggestions on getting them lined up? I am at TDC on #1 and I started the belt from the crank and up the drivers side cams.
Thanks in advance.
