TwinTurbo.NET: Nissan 300ZX forum - Re: Starter grind
Subject Re: Starter grind
Posted by ZBOOSTT on October 04, 2023 at 8:18 PM
  This message has been viewed 310 times.
In Reply To Starter grind posted by Hiruzaiz32 on October 04, 2023 at 11:28 AM
Message Sounds like a busted gear on the flywheel. My Z1 flywheel did the same thing. 2 teeth chipped. It would sound horrible as it went over those chips, but then start fine after it moved by them. If the starter solenoid is going out, it makes a rapid clicking sound. If it's the gear, it sounds like gears grinding.
