TwinTurbo.NET: Nissan 300ZX forum - could be a worn down ring gear. not sure how pumping the
Subject could be a worn down ring gear. not sure how pumping the
Posted by slayer fan on October 04, 2023 at 4:59 PM
  This message has been viewed 330 times.
In Reply To Starter grind posted by Hiruzaiz32 on October 04, 2023 at 11:28 AM
Message clutch does anything between the starter and flywheel. unless you have a lot of endplay in your crankshaft and your thrust is out of whack. it could also be a weak ground and your starter is not engaging fully. i would run extra ground wires. i do it for all my vehicles. you woud be surprised how small the ground cable is on a honda civic si.
