TwinTurbo.NET: Nissan 300ZX forum - That is why the Conzult Software
Cjw3
on September 30, 2023 at 3:09 PM
Could this be a Throttle Body Position Sensor problem? (n/m)
posted by Denis
on September 29, 2023 at 07:53 PM
This allows you to see what the ECU is Seeing. If the TPS Sensor or Switch is not working properly, you can see it from Software without having to Wrench on things.
Same idle issue for YEARS and still can't figure it out...
BigDinNoCo
14:18:28 09/27/23
Boost Leak test, Checking for Leaking Throttle Body Shafts..
Cjw3
15:54:39 09/27/23
Re: Boost Leak test, Checking for Leaking Throttle Body Shafts..
BigDinNoCo
16:04:28 09/27/23
Please get Conzult Software and Cable..
Cjw3
19:59:06 09/27/23
Higher fuel pressure during hot start adds more fuel
LitlElvis
12:33:13 09/28/23
Huh? (n/m)
BigDinNoCo
18:25:05 09/28/23
It's a reply to member Cjw3 - my reply to you is below (n/m)
LitlElvis
12:08:25 09/29/23
Get qualified, professional help. (n/m)
23:25:55 09/27/23
For him or the car...?? (n/m)
Denis
09:54:29 09/28/23
LOL...yes, for both?? (n/m)
BigDinNoCo
18:23:59 09/28/23
Stabbing the throttle to get idle to change between dying
LitlElvis
12:51:01 09/28/23
Denis
19:53:51 09/29/23
That is why the Conzult Software -
Cjw3
15:09:52 09/30/23
On my Z when the idle does not go to normal at random >>>
ZUL8TR
07:29:27 09/30/23
