TwinTurbo.NET: Nissan 300ZX forum - Re: Boost Leak test, Checking for Leaking Throttle Body Shafts..
Subject Re: Boost Leak test, Checking for Leaking Throttle Body Shafts..
Posted by BigDinNoCo on September 27, 2023 at 4:04 PM
  This message has been viewed 379 times.
In Reply To Boost Leak test, Checking for Leaking Throttle Body Shafts.. posted by Cjw3 on September 27, 2023 at 03:54 PM
Message Hmmm...Thanks for the reply. I've done a ton of boost leak tests. I run 9lbs of pressure & the last time I did it, the only thing that made noise was the aftermarket dip stick that I just replaced with a new OEM one. I've also thoroughly cleaned the throttle bodies in the past. I'll try again, but wouldn't those be the first thing I'd hear?
