TwinTurbo.NET: Nissan 300ZX forum - I still think its a sticky caliper piston and the heat is
Subject I still think its a sticky caliper piston and the heat is
Posted by itsa300zx on September 12, 2023 at 2:26 PM
  This message has been viewed 310 times.
In Reply To Thanks! I rebuilt them myself. Went very smoothly so I’m posted by doug8867 on September 12, 2023 at 01:20 PM
Message just the resultant of the drag. I would remove the pads (assuming you put new pads in during the brake overhaul), place thinner used pads back in (this will give more piston travel) and apply the brakes several times then see which pad is stuck in the caliper.
At least will tell if outer or inner piston, or both. Maybe even do the same test after its hot. IDK
