TwinTurbo.NET: Nissan 300ZX forum - I hear a Miss.. the Mixture Looks proper by the O2 Sensors
Subject I hear a Miss.. the Mixture Looks proper by the O2 Sensors
Posted by Cjw3 on September 05, 2023 at 8:14 PM
  This message has been viewed 310 times.
In Reply To Re: Slight miss at idle, high idle, slight low speed hesitation posted by z3duececoupe on September 05, 2023 at 01:37 PM
Message However, if you have a Lean Running Injector, the ECU will Richen up that bank to get the average proper.. So now the some Cylinders are running rich and some lean on the same bank.. that will cause a Miss..
Might be able to read the Plugs..
Pull the Fuel Injectors and have them checked and cleaned.. Might be a fuel balance issue per cylinder..
Idle Cylinder Drop test might figure out where it might be..
Cj
