TwinTurbo.NET: Nissan 300ZX forum - Re: Slight miss at idle, high idle, slight low speed hesitation
Subject Re: Slight miss at idle, high idle, slight low speed hesitation
Posted by z3duececoupe on September 04, 2023 at 6:02 AM
  This message has been viewed 333 times.
In Reply To Slight miss at idle, high idle, slight low speed hesitation posted by z3duececoupe on September 03, 2023 at 08:55 PM
Message Forgot to mention that I also get a code 21 (ignition circuit fault). The code shows up immediately after an ecu reset but will always show "car has been started 0 times with this fault" despite restarting the car, so not sure if this is an after-effect of the PTU delete/Ls coils or if this is a legit problem and I need to recheck my coil wiring.
