TwinTurbo.NET: Nissan 300ZX forum - Re: OEM Transmission question... Help!!
Subject Re: OEM Transmission question... Help!!
Posted by MyBlueZ on August 30, 2023 at 2:44 PM
  This message has been viewed 345 times.
In Reply To OEM Transmission question... Help!! posted by Humble-Zed on August 30, 2023 at 01:51 PM
Message As itsa300zx mentioned in your post down below, the reverse check assembly or specifically the spring that controls its movement could be your problem. If that spring breaks it will lock you out of reverse. Tell your shop to unbolt that assembly from the side of the trans (1 bolt) and see if the spring has sprung. Here's what the assembly looks like (but yes it's discontinued as a unit).
https://conceptzperformance.com/nissan-infiniti-nissan-oem-300zx-reverse-checking-assembly-90-1192-z32-32180-33p03_p_7154.php
You can still get the spring -- part 32185-E9801. I see it on Ebay and looks like it's used on a bunch of newer Nissans too so should still be at the dealer.
Good luck.
