TwinTurbo.NET: Nissan 300ZX forum - I did simular..
Subject I did simular..
Posted by Cjw3 on August 22, 2023 at 7:23 PM
  This message has been viewed 265 times.
In Reply To Engine Swap posted by Spiderman73 on August 22, 2023 at 03:01 PM
Message I took a '96 NA Motor and drive line, and stuffed it into a '90 chassis.. Still driving it..
The Cams are debatable as to if you really want to swap them.. I did.. I put the 90 cams and actuators into the 96 Motor.. Some say you really only do it for the Bragging Rights..
Have to put new ends on the Injector wires.. Use the 90 CAS..
You will want to swap the T-Bodies over to be the 90's in the car.. The Idle Intake tube will also have to change.. It is bent different on the 96.
Not all really that hard to do..
Cj
