TwinTurbo.NET: Nissan 300ZX forum - It’s Out!!!
Subject It’s Out!!!
Posted by theKvR on August 12, 2023 at 10:37 PM
  This message has been viewed 237 times.
In Reply To Re: Re: Re: TT Oil Pan with engine in posted by plower1 on August 07, 2023 at 04:51 AM
Message Thanks for all the advice! I pulled the dip stick, I used a dremel cut off wheel to cut the thick top portion of the transmission bellhousing bracket behind the oil filter tree and as well ground the top captive nut. I then used a wrench to pry the bracket slightly and the oil pan came down.
Down the road whenever I pull the engine I will change the bracket and cut slots in the bolt holes. Ugh glad it is done.
"https://live.staticflickr.com/65535/53093550087_d7570c
793d_w_d.jpg” alt=“92 turbo 300ZX”>
