TwinTurbo.NET: Nissan 300ZX forum - Timing and lower manifold fitment
Subject Timing and lower manifold fitment
Posted by JMartz on June 15, 2023 at 8:00 AM
  This message has been viewed 307 times.
In Reply To shadetree explanation posted by shaggee on June 15, 2023 at 07:21 AM
Message As the distance between the crankshaft and camshafts is altered, valve timing will be affected, requiring adjustable cam pulleys. The location of the intake ports relative to their position on the "V" between the heads will change. Port matching between the head and lower intake manifold will be thrown off. This requires machining of the manifold to correct the misalignment between the ports.
Cutting down DOHC engines present a series of challenges
