TwinTurbo.NET: Nissan 300ZX forum - Re: Temp sensor aspirator fan?
Subject Re: Temp sensor aspirator fan?
Posted by Davez on May 29, 2023 at 5:41 PM
  This message has been viewed 364 times.
In Reply To Temp sensor aspirator fan? posted by Agent X on May 28, 2023 at 09:43 PM
Message Yea it makes sense. I had counted that out because I replaced that back in on 7/15/02 the original was making a bunch of noise. I haven’t heard noise from this one and I only put 10k miles on it since then its garage kept and the battery is disconnected. I will pull the map light down and see maybe this one is seized or something and not even moving. I assume that part is now discontinued. So I’ll have to see if this one can be fixed if it’s something I can’t do or find a used one I guess. Thanks you for the reply and link! It’s a start and hopefully the issue.
