TwinTurbo.NET: Nissan 300ZX forum - It's probably the rear oil pan seal.
Subject It's probably the rear oil pan seal.
Posted by Mongoose on May 29, 2023 at 2:17 PM
  This message has been viewed 300 times.
In Reply To Vacuum Leak from Rear Main Seal? posted by Pete1122 on May 22, 2023 at 10:02 PM
Message It's a small rubber gasket that goes on the back of the oil pan between the pan and the block. You don't necessarily have to drop the oil pan to replace it. But if you're doing it right, you probably should.
Have you ever replaced your entire oil pan gasket, or rear main seal? If so, did you replace this gasket as well? It's part number 11121-22P00. Here's a link: NissanPartsDeal.com It shows up as 11121 on the diagram.
That page also has a good diagram of where it goes. There is a metal retaining piece (12296 in that diagram) that goes over it and holds a different gasket (12296E in that same diagram). You have to drop the transmission to get to it.
That's also probably where your oil leak is.
-Jason
