TwinTurbo.NET: Nissan 300ZX forum - With that equipment, pull a vacuum
Subject With that equipment, pull a vacuum
Posted by Agent X on May 19, 2023 at 7:10 PM
  This message has been viewed 252 times.
In Reply To Ac high side and low side posted by Hiruzai_z32 on May 19, 2023 at 05:48 PM
Message If you don't have a vacuum pump you may be able to borrow one from your local parts store (what I did). Pull a vacuum on the system, shut it down and watch the gauges for a while. If no leak then it'll hold vacuum. This should help narrow down the problem if you can eliminate a potential leak.
Also make sure you have adequate air flow over the condenser while you're running the system.
Conversation between my sister and my wife (shortly before we
got married):
Wife: "You know, sometimes I think he loves that Z more than he
does me."
Sister: "He probably does, and as long as you're okay with that,
everything will be fine."
