TwinTurbo.NET: Nissan 300ZX forum - Do a voltage drop test.
mrchips
on May 07, 2023 at 6:38 AM
Re: Have you changed the battery cables? If you still have the
posted by coilerDH
on May 05, 2023 at 01:30 PM
You will need a digital multimeter and test leads with alligator clips. More than .30 volt drop when cranking is no good. Same goes for the trigger wire as that can be the issue too. Lots of videos can be found.
starter grinding
coilerDH
14:48:51 05/04/23
It could be a small section of teeth on the flywheel that
Polishzx
23:14:11 05/04/23
LitlElvis
10:45:23 05/05/23
+1 on this
MyBlueZ
13:22:36 05/05/23
coilerDH
13:30:03 05/05/23
Do a voltage drop test. -
mrchips
06:38:57 05/07/23
Re: Do a voltage drop test.
coilerDH
13:58:01 05/08/23
coilerDH
21:56:54 05/09/23
Re: starter grinding
coilerDH
22:00:13 05/09/23
coilerDH
13:04:00 05/10/23
