TwinTurbo.NET: Nissan 300ZX forum - No gears after transmission fluid change
Subject No gears after transmission fluid change
Posted by Monkeymantenn on April 29, 2023 at 7:20 PM
  This message has been viewed 302 times.
Message I have been having an issue with my transmission for several months. I ended up replacing the transmission control module and found that I had a code for the line pressure solenoid. Today I replaced the line pressure solenoid, transmission, fluid filter, and gasket. Prior to the fluid change, I was having hard shifts, which would also suggest the solenoid issue. After I buttoned everything up, I added five forts of ATF and checked the dipstick after the engine was warm. My fluid level shows full on the dipstick, but I have no gears. The engine does a rift between gears when you’re shifting nor does the car move in any gear now. I’m at a loss because I really did not change much. Has anyone experienced this before? I’m open to any advice greatly appreciate your input.
Thanks
