TwinTurbo.NET: Nissan 300ZX forum - Needle nose
Needle nose
TTwinTTurboZ
on March 31, 2023 at 2:10 PM
I’ve been able to just tighten it down using needle nose
posted by Kvert
on March 31, 2023 at 11:15 AM
I had no idea what tool to use on those two grooves so I did the best I could with two flat heads pushing each groove clockwise and it seems to be sealed now. Wish I would have read this earlier tho.
A/C Leak (picture of leak) advice needed
TTwinTTurboZ
14:17:07 03/30/23
Denis
17:13:28 03/30/23
Freon Type
TTwinTTurboZ
06:06:28 03/31/23
O-ring size
TTwinTTurboZ
11:11:16 03/31/23
Response
Denis
11:26:33 03/31/23
Thanks
TTwinTTurboZ
10:22:26 04/02/23
You're welcome. Make sure to NOT turn on the compressor
Denis
21:32:04 04/02/23
Oil
TTwinTTurboZ
05:55:59 04/05/23
you can usually rent a vacuum pump
Agent X
07:32:46 04/05/23
Best way to go unless you have several cars, then own one (n/m)
Denis
11:02:32 04/05/23
Kvert
11:15:30 03/31/23
Re: I’ve been able to just tighten it down using needle nose
TTwinTTurboZ
14:09:08 03/31/23
Needle nose -
TTwinTTurboZ
14:10:24 03/31/23
