TwinTurbo.NET: Nissan 300ZX forum - The CAS aligment mechanics are fairly robust to the point
Subject The CAS aligment mechanics are fairly robust to the point
Posted by LitlElvis on March 12, 2023 at 1:04 PM
  This message has been viewed 313 times.
In Reply To Ok. Found the problem. But don't understand what happened posted by Zxpress on March 10, 2023 at 12:34 PM
Message where if you have to force it to fit flat onto the CAS mount, this indicates there is a problem.
JWT claims that some CAS mounts are not centered on the exhaust cam that drives the CAS, which leads to abnormal wear to the splined drive. You might try checking this.
When you get it all fixed, be sure to apply some grease to the CAS drive splines and outer o-ring to help it all slide together easier and prevent wear over time.
