TwinTurbo.NET: Nissan 300ZX forum - Re: overheating a little bit, removing thermostat fixed it
Subject Re: overheating a little bit, removing thermostat fixed it
Posted by tian2bing on February 12, 2023 at 2:11 PM
  This message has been viewed 322 times.
In Reply To overheating a little bit, removing thermostat fixed it posted by tian2bing on February 10, 2023 at 08:24 AM
Message removing my water pump tomorrow.
need a tool to remove the under drive pulley, so that delayed the progress.
:But, its a new OEM thermostat and I drove it for only 500 miles.
:Tested the thermostat and it opens fine, to 14mm.
:After that, I've observed that the heater is lukewarm, does that mean the heat valve has a problem? If it does, will it be the cause of the overheating in the first place?
