TwinTurbo.NET: Nissan 300ZX forum - Re: Lets Discuss..
Subject Re: Lets Discuss..
Posted by tian2bing on February 10, 2023 at 12:41 PM
  This message has been viewed 278 times.
In Reply To Lets Discuss.. posted by Cjw3 on February 10, 2023 at 12:14 PM
Message new fan clutch ( OEM setup, no electric fan)
radiator no rust,
not losing any coolant
####water pump need to be checked#######
####block , don't know how to check######
timing is spot on.
now I want to know if a clogged or valve-restricted heater core will cause overheating. From the FSM, it seems it won't.
:Too Many Z are driving around with T-Stats, and are working Properly.. We need to figure out why Your Z is Running Hot..
:Bad Fan Clutch, Electric Fan Controls.
:Bad T-Stat.
:Bad Radiator.
:Radiator Loosing Water because of Bad Cap.
:Water Pump Lost it's Impeller.
:Block is Clogged.
:Timing is Retarded.
:These are the Usual Suspects for Heating Issues..
:You have already checked/Replaced the T-Stat.. What Else on this list have you checked.
:Cj
