TwinTurbo.NET: Nissan 300ZX forum - Additional Data
Subject Additional Data
Posted by Cjw3 on February 08, 2023 at 9:43 AM
  This message has been viewed 317 times.
In Reply To More data inside -----> posted by fantomZ(OH) on February 07, 2023 at 06:26 PM
Message AFR VS Voltage Chart Narrow Band Sensor
.07=16:1
.09=15:1
.45=14.7:1 ( Stoch)
.81=14:1
.9=12:1
When your Idle gets up and warm, your actual Mixture as reported by the O2 Sensors is ~ 14.67 AFR for both sides.. That is close enough to be considered its fine..
The O2 Sensor Voltage is only off by 0.01 Volt between them.. I'd say they are the same..
In this senario I see your Ignition Timing ( Last Vid ) is idling at 15 Deg as it should.. So the 'Idle Circuit' is operating Properly..
The 'Idle Hunt' will likely be a 'Sticking' Idle air control valve..
Back in the Archives ~ 2012 or so I think, there is a DEEP DIVE into a z with a Hunting Idle Problem.. It involved O'Scope Tracing and a LOT of work.. Ended up the IAC was 'Sticking' and was causing the Idle Hunt..
Cj
