TwinTurbo.NET: Nissan 300ZX forum - Its a Start Table that goes from -40C to +110C
Subject Its a Start Table that goes from -40C to +110C
Posted by Cjw3 on January 03, 2023 at 11:43 AM
  This message has been viewed 272 times.
In Reply To Re: I have a 90 NA that gives me fits as well posted by matt34533 on January 03, 2023 at 11:05 AM
Message It will add a Ms Pulse Width Adder to and Calculated Value during the 'Start Phase'..
I do not know if it's a Time Phase or if it waits till it sees activity on the O2's..
The Temp Detected is the Water Temp, as it has no Air Temp Sensor.. SOMEWHERE the Fuel Rail Temp sensor us used for calculations, but I'm under the Impression its only used for the PRV Activation..
My Map I've changed it from about 10C Down to -40C.. And that now Progresses from 9Ms at 10C to 24Ms at -40C.. I've not changed the Warm/Hot Start of my Table.. Starts at 5Ms adder at 30c to 60C.. ( same Value ) then 4@70c and 3 from 80C up to 110C..
Its easy to Just pad the Table a little bit if you can tell me what the Hot Start temps you read from the ECU Water Temp Sensor.
