TwinTurbo.NET: Nissan 300ZX forum - Re: If I continue to crank and pat the gas...
Subject Re: If I continue to crank and pat the gas...
Posted by matt34533 on January 02, 2023 at 9:13 PM
  This message has been viewed 258 times.
In Reply To If I continue to crank and pat the gas... posted by Zxpress on January 02, 2023 at 07:42 PM
Message You would think you would get a CAS sensor code in that case but possibly not, the ECU is pretty "dumb" compared to more modern ones. There are 360 tiny little slits that the light shines through which could get blocked. I had seen a post/article somewhere about cleaning it but can't find it now. I've done it myself. You just remove the 3 bolts that are on the side that faces towards the engine when it's installed (be careful not to strip them, they seem to be JIS Phillips which works with American Phillips but not too well). Then use a very small flat head screw driver to pry the case apart using the tiny slits along the side. Probably would only take 30 minutes if you're pretty quick with tools.
