TwinTurbo.NET: Nissan 300ZX forum - Re: No start saga continues.....
Subject Re: No start saga continues.....
Posted by matt34533 on January 02, 2023 at 6:21 PM
  This message has been viewed 250 times.
In Reply To No start saga continues..... posted by Zxpress on January 02, 2023 at 04:13 PM
Message My mistake I see you tested for battery voltage at the injectors. The results of test #3 and Test #5 that you did don't make sense. If the CAS is firing the injectors when cranking (noid light is firing) it should fire them when spinning it by hand. I would still be suspicious of the ground side wiring between the ECU and injectors #1-#4.
