TwinTurbo.NET: Nissan 300ZX forum - Re: No start saga continues.....
Subject Re: No start saga continues.....
Posted by matt34533 on January 02, 2023 at 6:16 PM
  This message has been viewed 255 times.
In Reply To No start saga continues..... posted by Zxpress on January 02, 2023 at 04:13 PM
Message Sounds to me more like a wiring issue. I would be testing for power at the injector connectors for #1-#4. I would also then test the ground side of each injector by testing for continuity between the ECU connector pins and injector ground pin for injectors #1-#4.
Also a question for you:
Are you getting 65psi fuel pressure when cranking?
