TwinTurbo.NET: Nissan 300ZX forum - Re: Re: If the problem started
Subject Re: Re: If the problem started
Posted by Drk93TT on November 10, 2022 at 5:40 AM
  This message has been viewed 233 times.
In Reply To Re: If the problem started posted by cm1wrx on October 20, 2022 at 09:32 PM
Message Would be a good idea to just replace them with new style injectors and the new style connectors soldered in. Be careful when you install the fuel rails back into the lower plenum. Grease them up as the instructions state with the lube they give you.. also put them ON the fuel rails first and then put the rails back into the plenum that will usually prevent any chance of a pinched o-ring...
Also on your FPR, could be a defective unit. Contact Aeromotive and see what they have to say.
