TwinTurbo.NET: Nissan 300ZX forum - 91 TT power steering failure
Subject 91 TT power steering failure
Posted by zshadow on November 09, 2022 at 2:21 PM
  This message has been viewed 375 times.
Message I replaced my power steering reservoir with a powder coated one and lost my power steering completely. I switched back to the original and still zero power steering. I replaced the pressure sensor and Solenoid valve with used ones and installed the rebuild pump from O'Reilly auto. Worked fine at first, drove it about two miles and power steering failed. Pulled the pump and both of the control valves were stuck like there was too much pressure. The HICAS light is not coming on so I'm thinking that isn't the problem but not sure. Suggestions, ideas on how to fix this?
ZSHADOW
