TwinTurbo.NET: Nissan 300ZX forum - Re: Also put a vacuum gage on when running to see what.>>>>>>
Subject Re: Also put a vacuum gage on when running to see what.>>>>>>
Posted by cm1wrx on November 07, 2022 at 1:50 PM
  This message has been viewed 286 times.
In Reply To Also put a vacuum gage on when running to see what.>>>>>> posted by ZUL8TR on November 07, 2022 at 09:47 AM
Message I will give it a shot. I sprayed some brake cleaner around the intake while someone was holding the throttle (engine running) just to see if I could get a change. Couldn't find any vacuum leaks but I need to test a little more thoroughly. I just received some more connectors from Z1 to replace the TPS, CAS and both IAC connectors. They are fairly cracked and worn out so I thought it would be a good idea for cheap insurance. Will report back asap. Thanks again!
