TwinTurbo.NET: Nissan 300ZX forum - Also put a vacuum gage on when running to see what.>>>>>>
Subject Also put a vacuum gage on when running to see what.>>>>>>
Posted by ZUL8TR on November 07, 2022 at 9:47 AM
  This message has been viewed 315 times.
In Reply To Re: Check that coil specs. Try switching that coil with one > posted by cm1wrx on November 07, 2022 at 08:34 AM
Message readings are and how steady (that is important). It may be old school but helped me many times thru the years with many cars I have worked on.
With engine at say 1500 revs you should get a very steady needle at about 20" Hg. You could have a vacuum leak that is messing up idle at around 700 revs. At idle the reading should also be very steady.
Here is a link on vacuum gage readings.
[ http://www.atlanticz.ca/zclub/techtips/vacuum/ ]
Compression test may not seem an issue but worth a look to see how healthy the engine is and especially the different psi values between the cylinders. Compression test values should be considered more of a relative test rather than absolute psi since different gages will give different results with different temps and other. I always use the same gage and do cold temp (to keep that variable close to constant and known) and keep track of the relative psi readings for future reference.
ZUL8TR
