TwinTurbo.NET: Nissan 300ZX forum - Re: Check that coil specs. Try switching that coil with one >
Subject Re: Check that coil specs. Try switching that coil with one >
Posted by cm1wrx on November 07, 2022 at 8:34 AM
  This message has been viewed 305 times.
In Reply To Check that coil specs. Try switching that coil with one > posted by ZUL8TR on November 07, 2022 at 04:40 AM
Message Tried moving the coils but the problem stays the same. I have noticed it runs a little smoother than before however it still won't idle on its own. Haven't done a compression test yet but will (I really don't think that is the issue based on what I have seen/am seeing). I have adjusted the TPS and made sure it is working. Will pull the IAA, clean and adjust next and see what happens. Thanks for the tip!
