TwinTurbo.NET: Nissan 300ZX forum - Running lean, hestitation at 3500rpm
Subject Running lean, hestitation at 3500rpm
Posted by Z Force1 on November 03, 2022 at 8:09 PM
  This message has been viewed 320 times.
Message Hi guys!
When mashing my foot to the floor (running stock boost without safety boost solenoids) it pulls hard but hesitates around 3500RPM.
I've been having a problem setting the timing properly, i have 3 CAS units, my original CAS was idling @ 40 degrees so i swapped for another and the other 2 can only go down to 17 degrees when turned fully counter clockwise.
I have 3 CAS units & find it hard to believe they are all faulty (one was running fine when removed from another car), a manual conversion with the neutral switch not wired up & an eprom tune. Conzult says the base timing is 15 degrees @ idle.
The car was running fine a few days ago even with this timing problem.
