TwinTurbo.NET: Nissan 300ZX forum - Did you try a balance test?
Subject Did you try a balance test?
Posted by Mongoose on October 31, 2022 at 9:59 PM
  This message has been viewed 284 times.
In Reply To Idle Misfire, Runs well otherwise posted by matt34533 on October 25, 2022 at 03:22 PM
Message At idle, after letting it warm up, pull the coil pack electrical connections one at a time. When you pull one, the engine should bog down considerably, and then should recover instantly when you re-plug it in. When you pull one and the idle doesn't change, that's your problem cylinder.
I've had your exact symptoms a few times over 17 years of Z ownership. Car would intermittently idle bad, but always ran smoothly at higher RPM. Every time it turned out to be either a failing injector, or a corroded injector connection.
You say up front that the injectors are suspect. I think you're right.
Good luck!
-Jason
