TwinTurbo.NET: Nissan 300ZX forum - Re: Check the ECU connector also
Subject Re: Check the ECU connector also
Posted by cm1wrx on October 15, 2022 at 1:36 PM
  This message has been viewed 290 times.
In Reply To Check the ECU connector also posted by Drk93TT on October 11, 2022 at 05:48 AM
Message pins look good. I just double checked the injectors with a noid light just to make sure they are firing. They are..... Spark is good.... fuel lines are clear. FPR is replaced. Fuel filter is replaced (for the second time). all fuel lines are new. ECU shows code 55 (no fault). Fuel pump is new (second pump). Plugs are new. Harnesses for injectors and coils are new. PTU is new along with the harness from Z1. Relays are new...... I just don't know what to do at this point.... Going to check voltage at the pump to see if it drops out.
