TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: So, if your plugs are dry and the car isn't running, it
cm1wrx
on October 15, 2022 at 1:25 PM
posted by cm1wrx
on October 14, 2022 at 10:40 PM
Fuel lines blown out. No restrictions. No change.
300zx Fuel Issues
cm1wrx
15:44:53 10/02/22
Are your spark plugs wet? (n/m)
23:50:33 10/02/22
Re: Are your spark plugs wet?
cm1wrx
09:51:45 10/03/22
Check injectors power supply and electric grounds. (n/m)
ZUL8TR
04:51:40 10/04/22
Re: Check injectors power supply and electric grounds.
cm1wrx
22:15:14 10/05/22
See if voltage is at each injector. Disconnect the >>>>>>
ZUL8TR
04:54:05 10/07/22
Re: See if voltage is at each injector. Disconnect the >>>>>>
cm1wrx
12:59:37 10/09/22
Check the ECU connector also
Drk93TT
05:48:23 10/11/22
Re: Check the ECU connector also
cm1wrx
22:17:21 10/13/22
cm1wrx
13:36:13 10/15/22
Re: 300zx Fuel Issues
Drk93TT
11:06:47 10/03/22
Re: Re: 300zx Fuel Issues
cm1wrx
15:38:56 10/03/22
cm1wrx
13:00:27 10/09/22
cm1wrx
18:32:01 10/09/22
cm1wrx
22:39:34 10/09/22
Woodnutz (PA)
19:07:31 10/10/22
cm1wrx
21:46:39 10/11/22
clog in the fuel path? (n/m)
Kvert
17:55:37 10/13/22
Re: clog in the fuel path?
cm1wrx
22:15:28 10/13/22
Drk93TT
19:01:17 10/14/22
cm1wrx
22:40:43 10/14/22
Re: Re: Re: Re: So, if your plugs are dry and the car isn't running, it -
cm1wrx
13:25:37 10/15/22
Re: Re: Re: Re: Re: So, if your plugs are dry and the car isn't running, it
cm1wrx
14:45:37 10/15/22
If the problem started
Drk93TT
16:35:49 10/18/22
Bypass the fuel pump brain.
mrchips
06:35:59 10/19/22
Re: Bypass the fuel pump brain.
Drk93TT
06:25:23 10/20/22
Re: Re: Bypass the fuel pump brain.
cm1wrx
21:35:01 10/20/22
Fuel pump
Drk93TT
05:25:51 10/21/22
cm1wrx
21:32:52 10/20/22
Re: If the problem started
cm1wrx
21:32:01 10/20/22
Re: Re: If the problem started
Drk93TT
05:40:57 11/10/22
