TwinTurbo.NET: Nissan 300ZX forum - See if voltage is at each injector. Disconnect the >>>>>>
Subject See if voltage is at each injector. Disconnect the >>>>>>
Posted by ZUL8TR on October 07, 2022 at 4:54 AM
  This message has been viewed 183 times.
In Reply To Re: Check injectors power supply and electric grounds. posted by cm1wrx on October 05, 2022 at 10:15 PM
Message connector and probe the supply harness for voltage. On the 1991 you have the factory wired each injector to always have 12v there even with key off (unless it was rewired to be 0 volts when the key is off). This was later changed (model year?) to be zero voltage at each injector when key is off. When running the computer controls the ground on and off at each injector based on a number of factors. So check for 12v at each when not running. If there is no 12v at the injectors then you have to go deeper into the electric supply between the injectors and the computer.
Report results for voltage at each injector.
ZUL8TR
