TwinTurbo.NET: Nissan 300ZX forum - bad radiator cap? Might be worth a shot, relatively cheap
Subject bad radiator cap? Might be worth a shot, relatively cheap
Posted by robo (sebring1970) on August 30, 2022 at 11:49 AM
  This message has been viewed 254 times.
In Reply To Overheating slightly still posted by TTwinTTurboZ on August 27, 2022 at 10:23 AM
Message I've seen replacing the cap fix hot running cars . . . never. But "they" say it can happen.
After the car is warmed up, protect your hands with some gloves from the heat and squeeze the large water hose coming off the radiator. The hose should feel like it's under pressure. If the hose does not feel like it's under pressure, buy a new radiator cap. I bet a new cap did not come with your new radiator, or did it?
One time I did this little test and the radiator cap started hissing and gurgling when I squeezed the hose, so I knew the radiator cap was not making a tight seal and needed to be replaced.
"Straight-line acceleration is probably the first aspect of
automotive performance that any intelligent driver gets bored with."
Peter Gregg
"We owe a lot to the dragsters.
They always break something,
figure out a way to beef up the part
and then the benefit trickles
down."
Robo
"Not everything that can be counted counts. Not everything that
counts can be counted."
Einstein
