TwinTurbo.NET: Nissan 300ZX forum - Isn't the entire engine made of dissimilar metals...
Subject Isn't the entire engine made of dissimilar metals...
Posted by LitlElvis on August 17, 2022 at 12:13 AM
  This message has been viewed 312 times.
In Reply To Re: Valve Cover Crush Washer posted by zman03 on August 16, 2022 at 06:44 PM
Message that all seem to work together peacefully without any measurable galvanic corrosion? Now if these metals are both regularly exposed to water or some other electrolyte, then by all means, choose your materials like they're going into a 787 and people's lives depend upon their not corroding... but this isn't the case with VG valve cover fasteners.
Crush washers were only used as OE on the intake valve covers, so I assumed that your leak originated from an intake valve cover... I forgot to remember that I should never assume that every Z32 owner knows where the valve cover crush washers should be used.
For exhaust valve cover leaks I recommend not using any sort of crush washer under the bolt heads, RTV gray, and these - https://www.bde-performance.com/exhaust.htm
