TwinTurbo.NET: Nissan 300ZX forum - New build idle issues
Subject New build idle issues
Posted by TT DNA on July 20, 2022 at 9:54 AM
  This message has been viewed 426 times.
Message This is for our endurance track car, we wanted to stay in the group we run with that's why it's an NA
We had an engine built and at the guidance of the builder he built a motor with 11:1 compression. It is a NA motor and he instructed us that we need to use the 370cc injectors for this motor. we had the ecu programmed accordingly to our build. The Car starts fine when cold and idles a little high the issue occurs when its warm. The car will not idle and we often have to give it gas for it to start. When its running at 3k RPM the AFR is between 15-17. Fuel pressure on startup is 43-44 and can go up to 50 when giving it acceleration. We have swapped out and set a different TPS, IDLE Air Control, MAF, CHTS, CAS
We are open to paying someone to look it over and get it running for us. located in Canton Ohio will deliver car
