TwinTurbo.NET: Nissan 300ZX forum - Re: Do you have the trans heat shield? Is there enough fluid in
Subject Re: Do you have the trans heat shield? Is there enough fluid in
Posted by Screwyluie on July 20, 2022 at 8:55 AM
  This message has been viewed 308 times.
In Reply To Do you have the trans heat shield? Is there enough fluid in posted by Bernie (NoVA) on July 20, 2022 at 03:06 AM
Message it's a swap so no hardline, it's a flex line from z1. neither transmission had a heat shield. There's heat shields on the turbos, and over the other lines running to the back of the car on the drivers side of the body. I made use of those to run the new line to give it protection. There's a heatshield behind the transmission between the driveshaft and the exhaust. That's about it for heat shields on this car.
it was slipping at first, so I re-bled the line and put in a higher temp fluid for the clutch. It does not seem to slip anymore that I've noticed.
yes there's plenty of oil in the transmission itself. MT-90 until it comes out the fill hole. as for a picture, not sure what you want a picture of, but here's an overall view https://i.imgur.com/n510yTB.jpg
