TwinTurbo.NET: Nissan 300ZX forum - Could be a Loose or Coroded Leg on the ROM
Subject Could be a Loose or Coroded Leg on the ROM
Posted by Cjw3 on June 17, 2022 at 7:49 PM
  This message has been viewed 278 times.
In Reply To Re: Sounds like a Bad ROM? posted by amezcuaz32 on June 17, 2022 at 01:32 PM
Message Pull the ECU, take the chip out of the socket, and then re-insert it.. that will scrape off the oxide from the legs and make a better connection..
DO NOT INSTALL THE CHIP BACKWARDS.. it is FATAL TO THE CHIP..
That should fix your problem..
Cj
