TwinTurbo.NET: Nissan 300ZX forum - Sounds like a Bad ROM?
Subject Sounds like a Bad ROM?
Posted by Cjw3 on June 15, 2022 at 8:58 AM
  This message has been viewed 293 times.
In Reply To can I use a 93 auto NA ecu on my 91 manTT for troubleshoot posted by amezcuaz32 on June 13, 2022 at 09:48 PM
Message Can you open up the ECU Case, and have a look and see if your ECU is Socketted?..
The Symptons are of Limp Mode.. Corrupted ROM, and the Main ECU can not read the Program.. The ECU Electronics will go to a mode where it at least able to make the engine run SOMEWHAT, so you can get it off the road..
It's an ECU thing.. You could also have water damage that will cause the ROM to be not readable sometimes..
Or just grab another ECU ( Ebay? ) and try that..
Cj
